4.3L engine rebuild - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-05-2002, 08:23 AM
Question 4.3L engine rebuild
Any help in finding rebuild kits for a 4.3L engines cheap! Gonna use it to replace a 2.3 carb Isuzu (weak) engine in a pickup.
Old 12-05-2002, 10:29 AM
1meancuda's Avatar
At a loss for words
Post
Check with Northern Auto or Summit. I'm not sure if Summit will carry anything like that, but it's worth a try. I think that I did see them in Northern, but I could also be wrong on that.
Old 12-05-2002, 06:25 PM
BOBCRMAN@aol.com's Avatar
Post
4.3 kits are not cheap! especially considering the pistons, rings and main bearings, oil pump lifters and valve train are all 350 chevy, the gasket set is overpriced, so are the cams and rod bearings.
