To keep the tbi you would also need the wiring harness for the engine and computer.I would find a vehicle at the salvage yard that has the same equipment as your engine.From that vehicle you would pull the ECM and wiring harness.
You would then be faced with the daunting task of wiring this into your vehicle.Can be done with alot of patience. The easiest route is to switch to a carburetor and standard HEI ignition.Here is a thread about that. http://www.hotrodders.com/t5437.html Hope this helps. |
I don't think there is a carb intake for the Vortec heads other than the cast iron q-jet marine intake. I was looking for a TBI intake for the Vortec heads so we could put a '00 vortec 4.3 in my moms '92 Sonoma and that marine intake was all i could find that would fit those heads. The only solution i could come up with was take the marine intake and put a TBI to carb adapter on it.
That was a few months ago so somebody might have came out with something else since then. |
