4.3L v6 to 383 sbc motor mount problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2012, 05:37 PM
brad33478's Avatar
I am swapping my 4.3l out of my truck and putting a steel sbc 383 that i had built. Ive been told by several people the motor mounts are the same but after pulling the v6 and measuring everything out when the 383 sits in there the block mount is about 4" too far forward.
is there an adapter kit for this?
i cant really put a weld in kit because on the driver side the steering is right in the way
thanks
brad
ID:	63065   Click image for larger version
ID:	63066   Click image for larger version
Old 02-18-2012, 05:52 PM
The truck should have different sets of holes for different motors .
At least the full size chev do .
There is a pile of S-10s with small blocks in them too
Some people use the pre 71 mounts on the S-10s
I put a V-8 in a 81 full size where a straight six was and had to move the mounts into the proper holes ..
Same mounts ; but had to move them
Old 02-18-2012, 07:47 PM
brad33478's Avatar
the trucks a 2006 chevy silverado 1500, theres no holes to change to but I actually ended up finding a adapter kit after awhile of searching. can use the stock mount locations and stock rubber mounts.
if anyone else is looking for the same thing here is the link
http://www.advanceadapters.com/products/pn-713123/
Old 02-19-2012, 05:21 AM
Richiehd's Avatar
JS-70
Hey Brad, Richie here! Are you sure that mount kit will work? It says its for S10, I thought you had full size Silverado.
Old 02-19-2012, 09:32 AM
topwrench's Avatar
Last journal entry: fish carb
I had to drop the lower a frames out of my 1990 C1500 to change the crossmember mounts to swap the 4.3 for an SBC
Old 02-19-2012, 10:15 AM
brad33478's Avatar
yea richie i spoke with the guy that left the review down below, he had put it on his 2001 gmc sierra 1500 swap and said it worked great on his stroker. Part should be in wed. or thurs so i guess we will find out
Old 02-19-2012, 10:30 AM
Richiehd's Avatar
JS-70
Keep that engine hoist as long as you need it
Old 02-19-2012, 03:55 PM
brad33478's Avatar
Hahah i didnt know you were on this forum richie, got all the serpentine set up and fuel/ wiring ready to go. hopefully ill be bringing it back to you in MY truck
Header and motor mount problem SthrnStyle3 Engine 13 04-13-2016 09:55 AM
How much clearance should there be between motor mount and motor mount bolt? firstgear Hotrodding Basics 7 03-21-2013 09:10 PM
motor mount problem chil53 Engine 2 04-20-2011 09:29 AM
Pontiac 3400 serpentine belt/motor mount problem ChevelleSS_LS6 Engine 3 06-15-2005 03:15 PM
Motor Mount ID Thom Laybourne Engine 3 09-17-2004 05:25 PM
