4.3l V6 rod bearings
I was wondering if anybody has any insight into the 4.3l vortec rod bearing failures. I currently have one with bad bearings and when looking for another used engine I had noticed that there seem to be allot with bad bearings. The one I have only has 73000 miles on it, I bought it from the original owner who was a handicapped elderly woman who by no means drove it hard. The oil pressure fluctuates from none to lots. I am in the process of tearing it down seems like maybe the pickup tube comes loose? Would like to correct what causes the failure. The engine runs excellent except for the hammering sound. Doesn't smoke no oil leaks she changed oil religiously. She gave me all of the service receipts it doesn't make sense why it would fail when it appears to have been looked after really well.
Any insight is appreciated thanks |
And who changed the oil? if it was any of the quick lube places they more than likely slapped on a new filter and pumped oil back in it that`s been run through a strainer a couple of times. Other than that thought, I agree with Tom, the gasket failures on these things were commonfold.
Like any other tool, they have their purposes, used properly. But use your head for pete's sake! Abrasive particles flying around at high speeds are not good around your engine! This just in, film at 11:00!
Yes. I get "Scotchbrite milled" heads in all the time.. These guys jusy don't have a clue to the damage they cause..
As for 4.3 bearing damage. I was told by a bearing guy. That the reason for all the front rod and main wear is becaose GM went to the large pickup tube on the oil pump. SBC chevies had no bearing problems since 55. Same with the 229 and many early 4.3's. All had the smaller inlet tube on the pump.. The reason, I was told, for the 4.3 problem, is when the engine is shut down. The oil naturally drains down to the pan. When the engine restarts. The extra internal volume of the large pickup tube creates a large air pocket that takes just an instant more to overcome and in that time the front rod/main bearings get starved or a weak air/oil combo from the oiling system. Causing just that little bit of wear. That plus the imbalance harmonics of this engine design really test the bearings. |
tom |
Well I got it apart quite easily actually. Just drop the front diff and down comes the pan. It is the rear most bearing that is pooched kinda weird you would suspect it to be the front one. I agree with the 3/4" pick up tube makes sense. A small block pump looks pretty much the same I will compare the two side by side. I know melling makes a 5/8" pickup for this pan so I will change pump and pickup.
Thanks for all the help |
i have done lots, and know people that have done LOTS more than me. of those intake gaskets. we all use the rol-loc disc's and scotchbright pads to clean the surfaces. we put rags down in the valley to keep junk out. we have NEVER had a problem. i guess it depends on how they are used.
this is the first i have heard about bearing problems. |
I understand there is a big difference in the diameter of the rod bearings on the 4.3 vs V8 engines.
Can someone verify this ? |
Craigslist is loaded with 4.3 engine'd vehicles that have knocking engines! Look around. You'll see what we are talking about. It appears to me this is a engineering/design flaw. |
Yes the rod bearings are larger on the 4.3. This was done to put more "meat" in the rod throws between the two adjacent rods on the offset pin grind. These cranks tend to be weak in this area even with the larger bearings. Very small cross section. Especially the front journal. I've seen many 4.3's ( including one of my shop trucks) break at the front journal. Usually junks the front main bore.
| what distributor for a 4.3L V6 Chevy | gmwillys | Engine | 23 | 04-11-2012 08:48 AM |
| Carb selection for 85 GMC 4.3L V6 | tn-cat | Engine | 5 | 05-22-2006 08:40 PM |
| Rod ratio | RobbieRat | Engine | 16 | 11-29-2005 06:52 PM |
| transmissions fit 97 s10 ss 4.3l v6? | boylanta | Transmission - Rearend | 5 | 08-24-2003 05:56 PM |
| Chevy 4.3L V6 to 350 swap | pitsen3 | Engine | 2 | 03-16-2002 09:22 AM |
