4.3l v6 valves - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2011, 11:55 PM
4.3l v6 valves
i took apart my 4.3l v6 in a later project truck i plan to build and the valves are sticking into the chamber about 1/16 of a inch as if its not seated is this what im getting right or do the older flat tap style 4.3 v6 have that kind of valves that stick down or is it like every other motor the valves should be smooth with the chamber or even alittle set into the head
Old 01-30-2011, 05:52 AM
Hippie's Avatar
Last journal entry: HEI comparison.
By "sticking" down I am presuming you mean the edge of the valve between the face and head is visble above the valve seat and not that there is a gap between the valve face and seat. This is perfectly normal on a production head that has not had a valve job since leaving the factory. In fact on a stock head if they were flush it would "possibly" be an indication of badly worn seats and/or valves. Not necessarily, but it would make me take a look. If they were heads I knew to have had a valve job or 2 I wouldn't be surprised. I'd still want to have them checked though. On a set of performance heads or stockers with a fresh performance valve job I would expect the head of the valve to be flush with the combustion chamber or very close to it.
Note, others may disagree with my thinking on this and they may very well be right. As I get older a lot of the automotive "sacred cows" I grew up with are finding there way to the Alpo factory. That's another post all in itself.....
Old 01-30-2011, 06:26 PM
myself i dont know these are the first heads lve looked at on a 4.3 ive seen v8 and toyota heads and they dont stick out of the seats
Old 01-31-2011, 03:41 PM
Hippie's Avatar
Plenty of SBC valves stick out too. One way to check to see of they are seated off the engine is to pour a little rubbing alcohol down the ports with the head sitting flat. There shouldn't be any seepage into the chamber.
Old 02-01-2011, 01:25 AM
what would be the hp gain if i get a set of vortec heads the motor is carb
valves foryota89 Engine 5 09-01-2009 05:21 PM
big valves or not? Augusto Engine 3 03-06-2007 02:29 PM
PVC Valves johnsongrass1 Engine 2 05-22-2003 02:53 PM
valves 70 nova Engine 2 05-14-2003 08:54 PM
ill try again (valves) matt_cooper Engine 2 11-15-2002 01:24 PM
