4.3L Vortec - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2006, 03:28 PM
chianesi's Avatar
Never Give Up
4.3L Vortec
Are all of the 1995 and up 4.3L vortec heads the same. If not, which years or casting numbers can I use on my 95 Blazer.
Old 01-31-2006, 04:13 PM
BOBCRMAN@aol.com's Avatar
No!!. The only heads that will fit your application have to have the same year/vin no. and casting number.. The 4.3 was undergoing a lot of engineering changes from 92 thru the late ninetys.. More than eight different heads thru the series. Minor differences that range from port shapes, bolt holes, temp senders, rocker arms and stands and studs.. Virtually no interchangability.. CLOSE but not correct.
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 03:50 PM
5.7 Vortec Heads Mustangsaly Engine 4 12-09-2005 07:48 PM
I love the 4.3L vortec v6 gmc43l2wd Introduce Yourself 1 11-23-2004 04:09 PM
NEW GMPP VORTEC heads !! terror385 Engine 1 07-11-2004 09:48 AM
4.3L vortec conversion fightingcody Engine 3 05-18-2002 09:41 PM
