4.3L Vortec to Carb Conversion? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2013, 09:07 AM
jaw22w's Avatar
I have a 1926 T coupe that I would like to put a 4.3 chevy v6 in. I have a line on a 48k mile 2000 4.3L vortec engine. My engine knowledge ends with carb motors. My question is: Can I remove all the electronic injection stuff and replace it with a manifold and carb? Edelbrock has a 4 bbl. manifold #2114 that looks to fit the vortec v6 heads. Is this as simple to install and run as it seems? What size carb should I run? Edelbrock recommends a 500 cfm unit. I want to run a 700 r4 trans. Can this be done with the edelbrock 500 cfm carb?
Also, what needs to be done for the ignition? I assume the ignition is controlled by the computer, so just replace the existing distributor with a hei?
I don't want any computers on this car as I just don't understand them. I appreciate any help you engine gurus an give me.
Old 05-13-2013, 10:12 AM
Sounds like you got a handle on it.
The 4.3 in the 1996-1999 full size GM trucks was rated at 200hp/260lb/ft torque. TBI 350's were rated at 190-210hp with 300 lb/ft torque.
My g-friend had a 4.3 V6 reg cab shortbox 2wd , 4l60e auto, 3.08 rear geared 1997 Chev pickup. I had 1992 reg cab 2wd, 700r4 auto, 3.08 geared truck but with teh TBI 350 engine. We would drag race adn I would get up on her out of the hole, but she would always walk by my truck before the end of the 1/4 mile.
Thats when I sold my 92 rcsb and bought myself a 1997 reg cab shoprtbox 2wd truck which ran a best of 14.8@94 with 2.007 60ft time. Bottom line, the 4.3 L35 you have will work cvery well in your light car.
Personally I would just run the EFI. Just use the PCM from the engine, run a high pressure pump that will feed at least 66 psi to the engine. The throttle response from an injected L35 V6 will be lost with a carb, but its your truck.
The 700r4 requires a TV(throttle Valve) cable to control line pressure and shifting. It mounts around teh carb and attaches to the carbs throttle arm
here is some Lokar stuff that wil work
Buy Lokar Throttle Valve Cables and Brackets from PATC
Not 100% sure if there is a mechanical fuel pump provision on teh 4.3 Vortec block, you may have to run an intake or inline low pressure pump regulated down to 8 psi to the carb.
A standard V6 HEI distributer will work fine for you.
Grab a carb with an air cleaner/breather ****embly.
Exhaust manifolds or V6 headers will work.
You may need to leave some sensors in the holes to prevent coolant/oil leaks.
You must use a squarte bore carb with the 2116 intake manifold
http://www.summitracing.com/parts/ed...s/?prefilter=1
The 4.3 is a 350 mius 2 cylinders, so a 500cfm carb is more than enough, just match it up to your intake.
Be sure you get good intake manifold gaskets, teh stock ones have been reworked a few times by GM. felpro makes a very nice aftermarket set with strong metal inserts, but they are expansive.
QMS98002T by Felpro these also come with upper and lower intake gakets as well as the centerbolt valvecover gaskets Unfortunately you cant get these lower intake manifold gaskets by themselves.
$85
http://www.summitracing.com/parts/fe...make/chevrolet
Stock type impregnated silicone gaskets by Felpro these also come with upper and lower intake gakets as well as the centerbolt valvecover gaskets
QMS95817 $42
You need to run good intake gaskets because, unlike older 4.3's the Vortec 4.3's and V8's use an intake manifold that has 8 intake manifold bolts which sit at 90 to the ground instead of 90 to the gasket face. This puts the gaskets in a constant state of sheer once torquyed. Then as teh engine heats up the aluminum lower intake expands more than the cast iron cylinder head causing the gasket to "roll", then it rolls agains as the setup cools. So every heat cycle causes this to happen. Eventually teh stock gaskets fail. These Vortec engines are notorious for intake manifold gaskets. On my Vortec 350(same setup as your engine) I have used the more expensive kit and havent needed new gaskets in over 100,000 miles. And that is on my 3 trucks all of which have Vortec 350's. The stock gaskets let go within 100,000 miles on average.
Stock style failed 4.3/5.0/350 intake gasket
Improved Felpro 350 gaskets, same construction of the improved Felpro 4.3 gaskets
This is a pic of a Dorman improved heater hose connection that screws into the intake manifold, this is made of better metal than teh stock connection. The stock material was pot metal and would easily break off. This is a much better piece.
But I suggest you use a standard water nipple such as this type.
Coolant comes out of the intake manifold through this nipple and feeds into the heater core.
The 4.3 should work very well for you.
peace
Hog
Old 05-13-2013, 12:34 PM
jaw22w's Avatar
Wow Hogg! Thanks so much for the information. That is exactly what I needed. As you said you prefer, I would run the EFI, but I would have no idea how to hook it all up, plus the engine does not come with the PCM. I know I will give up a little performance, but this is just a nice little cruiser. If I need an adrenaline rush I get in my 27 T roadster. 2000 lbs. with 450HP. I am surprised that the v6 vortec would outrun the 350 on the big end.
Old 05-13-2013, 02:24 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I'd want to use an aftermarket intake, but there are a few OEM options.
Some Chevy V6 info here.
I'd have to add that unless engine length were important, using a SBC V8 would be as cheap if not cheaper and will make more power all else being equal.
Old 05-13-2013, 03:57 PM
jaw22w's Avatar
I am leaving the car full fendered and the radiator in the original position. There is only 27" available in the engine bay. 31.5 " is needed for a sbc. I don't want to cut the firewall. So, length is the deciding factor and as stated above I don't want a lot of hp in this car. It is just for cruising. My wife may drive it. I don't trust her with a lot of power and I already have an adrenaline rush hot rod.
Vortec Head Conversion 1972RedNeck Engine 2 01-05-2011 04:33 PM
L31 Vortec Conversion to Carb. Ct Street Rod Engine 10 07-25-2010 06:21 PM
carb/fuel injected intake to vortec tb conversion plate 383silverado Engine 5 09-09-2007 10:36 AM
vortec conversion ? slim69 Engine 1 11-08-2004 08:40 PM
4.3L vortec conversion fightingcody Engine 3 05-18-2002 09:41 PM
