Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Is the 4.3V6 TV cable bracket same as V8
Old 12-31-2007, 10:29 PM
Stroke Stroke is offline
trans is '90 700r4, the intake is an Elderbrock, the engine is '95, without computer. The carb is quadrajet, older model.
More than likely your intake's bracket mount is in a different postion than what the cable is made for, or your bracket is for a different set up. Either or, no matter. You need to get it right. The adjustment should be the same as for the trans with that carb (or similar Qjet). Some carbs require the use of linkage accessories for proper geometry during operation. This is important to get right or you will cook your trans.
