The bracket bolts down right, but the bracket may be wrong. It's a GM cable for the S10, I think its the right cable for the trans. It might the arm on the Qjet. It came on a '67 chevy 327. I was wondering if the arm on the Qjet could be different from the later Qjets causing the problem. I wanted to stay with a GM bracket, but I may have to go after-market.
I will check with the parts stores and see if the brackets are different, and also see if the arms on the carbs are different. Thanks
