4 to 5 lug conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2013, 11:23 PM
Last journal entry: 1976 Chevy Monza 2+2
So I have a 1976 Chevy Monza 2+2 and I would like some nice wheels to go with it but I can't find any that are 4 lug. My question is do you know of any kits to convert to 5 lug for my car?
Old 10-24-2013, 08:19 AM
Wiki Edits: 27
google?
google is your friend, Several hits for rear axles.
H-Body/S10 5-Lug Front Suspension Upgrade Step-by-Step Guide: By Bob Gumm
Old 10-25-2013, 08:46 AM
kso's Avatar
kso kso is offline
The S-10 conversion for the front is pretty well documented and you get bigger brakes that way too. Otherwise some front discs can be re-drilled, others cannot...it depends on the individual casting, as some replacement parts are flat on the back side but most have reinforcing ribs that interfere with laying another pattern on. Rear axles and drums can be re-drilled, there is just enough room. It can be done on the car if you make a template and can drill straight holes, otherwise you'd want to pull the axles and find a shop to do it right.
Old 10-28-2013, 10:17 AM
gerbsinmd's Avatar
For the rear, it really doesn't make sense to get them redrilled. An s10 2 wheel drive axle will fit with no issues. Get the brake drum from the same and you are done. I did it in less than an hr on my Monza for less than $100 including the axles. Make sure you get a 26 spline axle and its breeze.
There are used 26 spline axles on ebay frequently.
chevy, conversion, kit, wheels
Mustang 4 lug conversion to 5 lug and bigger brakes 1931gt Suspension - Brakes - Steering 17 06-03-2011 07:44 AM
4-lug to 5-lug conversion syco28 General Rodding Tech 1 11-16-2006 07:22 PM
C10 6 Lug to 5 Lug Conversion Quick66 Transmission - Rearend 6 12-25-2005 03:35 PM
6 lug o 5 lug conversion 61Chevy Transmission - Rearend 2 11-10-2003 08:02 PM
six to five lug conversion camaro75 Suspension - Brakes - Steering 1 09-27-2003 01:41 AM
