4.51 rear??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-06-2012, 05:16 AM
4.51 rear???
On my 65 C10 i pulled the rear apart and found 4.51 gears how do i go about finding the right rear for it thinking about 4.10. Im looking to put a 6.0 with a 700r4 if a dooner cant be found i might change to a 76 350 with 350-400 thdro?? with add on fuel inj. eather engine there not goint to be built for prof just enjoyable driving.
Old 12-06-2012, 10:40 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
My '65 had 3.73 ratio in the 12bolt 8.875.. Inline 6, Muncie SM318 trans..
Maybe yours was changed somewhere along the line.
Easy to figure, count ring gear and divide by pinion. Common ratio numbers in these are 3.08, 3.42, 3.73, 4.10, 4.56..
With a .70 OD, a TH700 would be nice with a 4.10. Much more than this, first gear (3.06) would be about useless..(IMO)
Old 12-06-2012, 11:00 AM
prostreet6t9's Avatar
Differential/Driveline
C10 is correct.. Should be a 12 bolt.
Maybe just regear your diff so you know what you end up with and better end product?
rear brake lines wheels to rear end center Studedean Suspension - Brakes - Steering 4 12-23-2011 05:38 PM
SBC 400 Rear main Vs Rear Oil Pan Seal afsog Engine 12 02-12-2010 04:56 PM
Welding a rear brace on a ford 9 inch rear end makaveli200369 Transmission - Rearend 4 07-02-2009 10:19 AM
1/2 tonn burb rear and 1/2 tonna blazer rear.. u joint? boneyard Buick Transmission - Rearend 1 10-08-2006 11:46 PM
67ssdiagram showing how the rear sway bar and control arms connect to frame and rear DeathByGreaser Transmission - Rearend 0 02-08-2003 08:10 PM
