Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4.56/3.73 Gears
Thread: 4.56/3.73 Gears
Old 12-01-2011, 10:35 PM
SSedan64's Avatar
SSedan64 SSedan64 is offline
Very doubtful, you would still need to check Pinion preload, Gear backlash, and Wear/Mesh pattern when swapping Ring & Pinion and Diff. You could start with the stock Shims & go from there.
