i have been told that this is a good book
thats the best that i can help i dont know of any web postings |
Re
Friend of mine just showed up about an hour ago saying he had something for me. It was a rearend, eventhough I've already ordered a gear set. But the id tag reads as follows
S390D 373 A75 8E04 Can anyone tell me what this is out of? He knew I was looking for a set of 3.73 gears. But I'm just curious for my learning curve, is this an 8.8 in. rearend and would it have worked in my 88 Mustang 5.0? |
Re
I realized what I said after I posted that. So, I did'nt cancel the order, and now I have 7.5 in. rearend layingin my garage. More junk for my wife to fuss at me about. Who knows, maybe it will be needed one day.
This Link is for a GM 8.875" 12-Bolt Diff rebuild, the Ford 8.8" Diff is basically the same style Rear. It's a very detailed Build so it should help you out.
http://www.webrodder.com/article.php?AID=134&SID=60 One more >> http://www.hotrod.com/techarticles/d...install_guide/ Using a Solid Pinion Spacer would make the Install much easier, you don't have to worry about all the torque required for that Crush Sleeve. |
Another question just for learning. So if I pulled a 8.8 rearend with 3L73 gears out of an ford explorer, could the entire assembly be swapped into a Mustang 8.8 without messing with the shims or bearings, just a straight swap? Not the entire axle, just the gear assembly and pinion?
Very doubtful, you would still need to check Pinion preload, Gear backlash, and Wear/Mesh pattern when swapping Ring & Pinion and Diff. You could start with the stock Shims & go from there.
but it would be a cheap way to get a set of gears and a 31 spline carrier
there is a chance it will be close and maybe between the two rears, you can put something together without having to buy too many parts
http://www.youtube.com/watch?v=Zgl5xcZmWpI
this might help its on a new f150 but it should be about the same idea? |
| **How may gears do you want?** Do we really need the 6-7-8 gears in today's trans? | CometCyclone | Hotrodders' Lounge | 32 | 11-06-2011 08:49 PM |
| swapping 2.56 gears to 3.50 gears | shmiv | Transmission - Rearend | 9 | 05-16-2009 09:18 PM |
| what gears do I have | eatonde | Transmission - Rearend | 3 | 10-17-2008 06:05 PM |
| Tranny gears or rear gears? | strummin67 | Transmission - Rearend | 4 | 06-12-2006 10:17 AM |
| 4.11 gears??? | 71gtx | Transmission - Rearend | 10 | 09-11-2003 10:59 AM |
