4.56 speedo gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2007, 02:32 PM
4.56 speedo gear
Is it true that you cant get a transmission speedo gear at that ratio?
Old 03-15-2007, 03:43 PM
no...4.56 gears speedo gears are available for some tranny's
here's a link incase you bet somebody a beverage:
http://www.transmissioncenter.net/sp...n_______va.htm
yes....they are not available for every tranny ever built and getting harder to find for some
from memory (LOL!)....1970 Cobra Jet R code "drag pack equipped" factory stock was 4.56 gears....with a correct factory speedo gear
Old 03-15-2007, 07:47 PM
oh wow. i forgot to say what tranny i have.... turbo 350
Old 03-15-2007, 08:03 PM
I do not think so ... for a 4.56
I had a Chevelle and a Camaro with 4.10 gears and both had a ratio adapter.
Most any speedometer shop has them or can get them. Lots of them on eBay too ...
Old 03-15-2007, 08:25 PM
damn. thanks anyways
Old 03-19-2007, 01:04 AM
Depends on your tire diameter. According to the Novaresource site, gears are available for 4.56 gears and 26.8" tires. A 7-tooth drive gear and a 24-tooth driven gear will make that combo work. Tires smaller than 26.8" would make the speedo read faster than actual speed, and vice-versa.
That assumes a Chevy-type T-350 speedo gear (3/4" diameter driven gear). A BOP-type T-350 has a larger speedo gear, and much wider coverage of ratios.
http://novaresource.org/speedo.htm
TH 350 Speedo Drive Gear Mr Bob Transmission - Rearend 11 01-12-2007 05:37 AM
THM speedo gear seal mhamilton Transmission - Rearend 4 02-19-2006 10:36 AM
12 bolt 4.56 gear ? jody chevelle Transmission - Rearend 8 02-04-2006 12:19 PM
TH350 speedo gear color john69 Transmission - Rearend 7 12-12-2004 07:57 PM
TH-400 Speedo Drive Gear Replacement 454impala69 Transmission - Rearend 6 03-17-2002 03:03 AM
