ive heard of them in a fiero; also n-stars in the fieros. never heard of them in a rwd app. i say go for it!
Check out this website, it has a lot of good parts for the Northstar engine. Definitely a cool looking engine for a hotrod.
http://www.chrfab.com/ |
I have a 4.9 which is the 4.5's big brother that I was going to swap into a GM W-body and while doing research I came across a website where a guy had swapped one into a 4WD. He had to fabricate mounts but IIRC it was a pretty easy swap. The 4.1/4.5/4.9 Cads have the same bellhousing pattern as the Chevy 2.8 V-6 and this guy used a 2.8 S-10 5-speed and transfer case. You have to get a custom flywheel to use a stick but those are available as the Fiero guys use the Getrag 5 speed transaxles behind them. A 700R4 or 5 speed from a 2.8 S-10 or Camaro would be a good trans choice. Google "V-8 Fiero", I think that's how I came across it.
Here's a good site for swap info for the older OHV Cad V-8's. Fiero Addiction |
Don't recall that but could be. I know they use the same bellhousing pattern and transaxle as all the other V-6 FWD GM's from the 60 Deg. 2.8 through the 90 Deg. 3.8. They are only about 30 Lbs. heavier than a 2.8/3.1 and are actually lighter than the 3.4 DOHC. HP output is about the same as a Series I 3.8 but TQ is quite a bit more and except for goodies for the HEI distributor there is ZERO aftermarket for them. But if you have a good one and are feeling creative......... what the Heck?!
| Caddy Brake Fun & Does Line Size Matter? Help Needed. | bigfred1958 | Suspension - Brakes - Steering | 5 | 04-06-2006 08:20 AM |
| '58 caddy engine | bigwoodbass66 | Engine | 1 | 12-29-2005 03:38 PM |
| HRM Caddy Chevette | dh79 | Hotrodders' Lounge | 6 | 06-10-2004 05:11 PM |
| Caddy 390 engine advice/review | mwc | Engine | 3 | 08-20-2003 08:21 PM |
| 500 Caddy in a Monte. | HemmiGremmie | Hotrodders' Lounge | 7 | 12-04-2002 02:53 PM |
