Thread Tools Search this Thread share on Facebook
  #1
Old 01-24-2012, 03:49 PM
rangerriderhp rangerriderhp is offline
4.6 / 5.4 DOHC Swap
I am interested in doing a DOHC swap in my 2002 ranger Edge. Does anyone have any previous experience or know of a link I can check on?
Register now (free) or login to remove ads
Old 01-27-2012, 05:42 PM
LATECH's Avatar
LATECH LATECH is offline
Last journal entry: Tips
ranger did not come with a 4.6. The 4.0 was the largest and they are a 60 degree engine.They are narrower than a 90 degree engine
Seems like the 4.6 and 5.4 are the same, as far as size and bolt up , but you would need to run the pcm with the engine it came with due to calibration.
A dohc motor like these may not fit a ranger.
I do know a 5.0 can be fitted in, and a 97 explorer has the low profile intake to make it work.The moduler engines are pretty wide and may not fit.
If you have a 4X4 the 5.0 fits well with a body lift as there is a clearance issue at the air conditioning box under the hood.The valve cover is too close, but lifting the body 2-3 inches gives good clearance.
Old 01-27-2012, 07:01 PM
Blazin72's Avatar
Blazin72 Blazin72 is online now
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Does is have to be DOHC engine? SOHCs are going to be easier to find and will probably be a somewhat easier to fit. An older 5.0 or 289/302 would probably be a much cheaper and easier swap.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "4.6 / 5.4 DOHC Swap"
ThreadThread StarterForumRepliesLast Post
Questions on the Ford 4.6 DOHC and 5.4 DOHCNightfireHotrodding Basics2109-25-2011 06:15 PM
4.6 DOHC In A 32: Anyone Did/Doing It345 desotoEngine1312-19-2008 08:03 AM
T-Bucket 4.6L DOHC modular motor swap update (sorry, but I kind of wrote a book)ArrowheadHotrodders' Lounge205-31-2006 09:39 PM
4.6L DOHC SOHC SwapWildcat66Engine104-15-2005 04:29 PM
4.6 DOHCElite347Engine010-02-2002 06:50 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
