4.6 in 55 fairlane
Hello,
I was wondering if anyone has done this or seen it done? If so can you point me in the direction I need? I have a 4.6 and aode I want to swap into my fairlane. My plan is to install the fatman front clip and not sure what to do for the rear. Any help would be great ! Thanks, Eddie |
what you talking about Willis??
A 4.6 what, with what trans? What's a 4.6 anyway?? A 5.0 is a 305 but what is a 4.6??
Tazz Rat Rods Rule! |
i know someone that has a 4.6 in a 63 Galaxy 500 2dr, hes built many chevy & ford panels & p/us but this the 1st 4.6 (i think) want his # ?
Mustangsaly |
You wouldn't really need to change the front suspension to MUST II on it. In fact, the '55 would be stronger.
There are 4.6L carb intakes and distributors out now. Which way do you plan to go? |
I have seen them for a 99-up dohc. Also you would not do the fatman front end? I wanted to convert to discs and thought that would be the best way and give some room for the new motor. Thanks for the help. Eddie |
The one I have is a 4.6 DOHC from a 98 lincoln mark 8. It is the aluminum version. And the trans will be a aod or aode if i keep it EFI. |
[QUOTE=Mustangsaly]i know someone that has a 4.6 in a 63 Galaxy 500 2dr, hes built many chevy & ford panels & p/us but this the 1st 4.6 (i think) want his # ?
That would be great if he don't mind! Thanks!! Eddie |
I will do some searching today for a swap kit. I believe I have seen one offered. |
[QUOTE=h8louzn]
Lofquist Welding Inc Elwood, NE 68937 308-785-2755 Steve Home 785-2938 i think he went with a mustang II frond end and air bag set up. nice guy. cars not finished yet. Mustangsaly |
Thanks,
I will give him a call! |
Lots of people go with the MII setup because they think it's best -- has to be "everybody" uses them! Well, if you HAVE to change the front suspension they are quick and easy -- the SBC of front ends! But they aren't necessarily "better" than the stock independent front suspension (IFS). In many cases they are actually worse! You can't get the range of motion out of the strut rod suspension that you can a real double A-arm setup. Eliminating the strut rod helps tremendously, but make sure you get a crossmember that can take the addes stress! The main reason for the MII swap is just what you were thinking -- easier availability of parts. But if there's an affordable way to upgrade the brakes I'd keep the original suspension. Unless you're going to be road racing it will be as good or better than anything you can weld in with much less time and work invested. This is true on just about any car with ball joints, and AMC/Rambler cars from 1950 with trunnions. If you have king pins or a straight axle and want to improve ride you need to switch to the MII or a derivative.
The mod Ford is wider near the top, but about the same near the bottom as the SBF. You should be able to modify the 55 mounting points to accept the Lincoln mounting pads. I'd keep all the electronics and EFI too. If you have the old Mk 8 available to pull everything from it should be easy. The computer wiring is pretty integrated. Once everything is pulled and dropped into the older car you should be able to connect power and ignition then run. I don't know about the gauges in that year Lincoln -- some years feed off the computer instead of separate sending units for some (or all) gauges. You will have to modify the trans mount, but if you have the Lincoln crossmember that should be easy enough. You can probably modify the Lincoln CM to fit the 55. |
Any 302 or 351 will almost bolt right in. uses the old radiator. modern engines upto about 400ci are actualy lighter and smaller than the origional 312 those cars came with.
Use a 86 mustang motor mount or a ranchero. plus a small spacer block. I've seen upto a cadilac BB but then there was a LOT of cutting involved. Lincoln Mk8 rear disk brakes work they are easily hooked upto the old parking brake cable. You'll have to make up adaptor plates. To make the Granada front spindles work all you need do is retaper the lower ball joint hole to fit the old ball joint. The same taper for the tie rod ends. After that they just bolt right on. Disk brake mastercylinders work from mustangs with little modifying, the same with some lincolins. |
Thanks for all the help guy's and girl's!
Can't wait to get started on it. I have the whole lincoln except the body. Even the rear seat looks like it will work. It's 1" wider than the stock one. I guess I will stay with the stock front end for now and spend the 2000.00 on paint. It will get it on the road a little faster. |
I have looked and found no conversion kit for the swap. Would a set of FORD installation drawings help you with the engine mount design? The only thing I see right off-hand that will interfere with the installation will be the heater box/motor on the right apron. A guy did a '56 with a 460 and I will try to see how he got around that problem. Were you able to keep the cooling module (rad/fans) from the MARK? And please put this on a project page so others can see how you solve the problems with the swap. |
| All times are GMT -6. The time now is 12:05 PM. |
