Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4.6 cooling problem
Old 12-22-2005, 10:18 AM
1931 steve's Avatar
1931 steve 1931 steve is offline
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
The only fix is to replace the manifold with a updated version (all aluminum). The cooling fan will run with the defroster on or the A/C on, and also when the engine reaches a set temp to command the fans on. Check with your local Ford dealer this may be under a recall.
Steve
