4.6 swap wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2011, 08:13 PM
77bronco_ed's Avatar
4.6 swap wiring
For those who have performed a 4.6 swap how did you approach the wiring?
98 4.6 dohc cobra motor/5 speed transmission
I plan to do a swap however I would like to find out the best easiest and/or the most cost effective approach before getting started on any wiring.
I will have entire engine/body harness and ECU
Thanks,
-Ed
Old 07-18-2011, 08:29 PM
LATECH's Avatar
If you have the entire powertrain harness then you got what you need, just get to mounting on your ride.Good lookin out getting the harness with all the fixin's
4L80E Wiring Harness Swap? RVowl Transmission - Rearend 2 10-13-2010 12:01 AM
Best wiring manufacturer for an -89 L98 TPI swap? Customikes Electrical 6 09-06-2010 10:15 PM
wiring issues after engine swap chevy1500z71 Electrical 14 04-30-2009 07:14 AM
im having wiring problems with an engine swap ntx_gearhead Electrical 6 03-06-2007 11:53 PM
1996 460 efi swap wiring. Jared Electrical 10 11-19-2006 01:18 AM
