4.6L to 5.4L engine swap. - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-31-2010, 08:34 PM
hey. I have a 97 f150 with a 4.6L with a manual trans. the motor is on its last leg and i wanna know how much work is involved in swapping it for a 5.4L(i.e. different computers, wiring harnesses, will my flywheel mate up with a 5.4,etc.)
Old 09-01-2010, 08:32 AM
53fordguy's Avatar
Junkyard Kustoms
Last journal entry: update after a long time
these modular motors are the same it should bolt up, get the motor harness and pcm it should all plug and play.
id get the harness cause some of the 5.4 2v use eot sensors in the side of the pan. depending on your year of donor engine, the ealier 4.6l use dual coil packs rather than the coil on plus design. 4.6/5.4/6.8 are all the same bolt pattern.
53 fords rule!
1995 suburban engine swap SBCfan04 Engine 2 07-17-2010 08:21 PM
53 Packard Clipper Engine Swap? 53packard Engine 16 07-06-2010 04:32 PM
'66 mustang engine swap RacinJason68 Hotrodding Basics 8 04-19-2010 08:43 PM
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
4.6L Cobra Engine Swap 88cobra Engine 1 07-18-2004 05:27 PM
