Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4.6L Ford
Thread: 4.6L Ford
Old 01-23-2004, 02:50 PM
Biggarmike's Avatar
Biggarmike Biggarmike is offline
Chief Procrastinator
I've found one little bug in the 4.6L which merits remembering: there are freeze plugs under the timing chains, which are steel from the factory. A lack of cooling system service or using improper coolant can cause them to leak, giving you all of the indications of a cracked head or blown headgasket. before you start a major teardown or junk the motor, pull the timing cover and have a look. (pressure test won't help you) The timing cover is surprisingly easy to remove and can save you big bucks and major labor.
