4/7 swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2008, 06:03 PM
4/7 swap
on a small block chevy is the 4 7 firing order swap worth that much power or torque? Also with the improved quality of poly locks are valvle lash adjustments still required if the engine doesn't see alot of 5500 plus hits on mechanical solid?
Old 06-17-2008, 06:22 PM
There are a few 4/7 swaps that work great... depending on the application. What CI, heads, intake, CR, trans, gear,usage?
Old 06-18-2008, 12:26 AM
327NUT's Avatar
If you do a search you'll see that the 4/7 swap is basically intended for multi carb BIG inch race motors.
Old 06-18-2008, 06:58 AM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
The 4/7 swap is designed to help out with the harmonics of the firing order, with less vibration comes more HP. However, if the rest of your rotating assembly and valve train isn't top notch stuff and fully balanced within half a gram then it is a waste of money to do the 4/7 swap.
I have a solid roller on my BBC with a set of arp 12 point rocker nuts with poly locks I only adjust them about once every year. And usually they aren't even out of adjustment.
C4 tailshaft swap? 70chevyc10 Transmission - Rearend 1 07-06-2007 06:49 PM
Cam swap Questions wayfast77 Engine 3 10-18-2006 04:52 AM
Found this site looking for swap info Roadrod Introduce Yourself 1 11-07-2004 10:16 AM
4/7 swap cams? KeithB123 Engine 4 02-20-2004 06:06 AM
