Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4 of 8 cylinders working on sbc350
Old 01-01-2013, 06:31 AM
lakeroadster's Avatar
lakeroadster lakeroadster is offline
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
If they are the back 2 plugs on both sides of the engine the problem is the secondary float level on the back two barrels of the carb., if it's the front 2 plugs on each side it's the primary float level. The needle and seat valve is likely stuck open allowing fuel to drip into the manifold, flooding the 4 cylinders. My Holley did the same thing last year, which is fairly common on Holleys.
Take off the air cleaner and look into the carb., if you see fuel dripping in the back two barrels, or the front two barrels you have identified the problem. Here are some video clips I posted showing the problem.
Some guys will tap on the rear adjusting nut to see if that will pop it loose. Here is an excellent Holley video on Fuel Level & Float Adjustment. Go to about the 3:00 minute mark.
And here is a video showing removal of the needle and seat valve.
Hope that helps and good luck to you!
The Following User Says Thank You to lakeroadster For This Useful Post:
Phat Juan (01-01-2013)
