Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4 of 8 cylinders working on sbc350
Old 01-02-2013, 11:32 AM
Phat Juan's Avatar
Phat Juan Phat Juan is offline
Originally Posted by sirron View Post
i had the same problem with a 396. Chevy engines are numbered "1-3-5-7" on drivers side and "2-4-6-8" on pass side. On a dual plane intake if you follow the air intake runners, 1,4,6,7 use half of the carb and 2,3,5,8 use the other half. I pulled the holley carb and found junk in one of the metering blocks. Rebuilt carb, fired her up and had all cylinders running about the same temp. I used a infrared temp gun on the header pipe at the head.i you don't have a if gun, take a water bottle cap of water and dump it on the header tube, if it boils off fast that cyl in working, if it kinda runs off that cyl is not working. This will work on cast manifold as well but not so evident. Yesterday a 350 had a intermittent miss, found one cylinder cold replaced wire no more miss. These infrared temp guns are great. I would look into it might have to return that "rebuilt" carb for another try.just something else to think about. Good luck
@sirron....well now that u point that out then it will be 1,4,6,7 that are not working properly. I should go to the carb shop once again and tell them that those cylinders are not working. What is it that they need to fix on this exactly so i can mention it to them?
