4 bar & panhard
Put a four bar set up under my 37 ford. Can I get by without using a panhard bar.
but you can put a track locater.. You have to have something to keep the axle from moving side to side.. ![]() You will need to use a panhard bar,or a track Locater,or a watts link..You do have to use one... |
Thanks for bring this up Frisco... I should of said something about this... I guess my head's in my A** today..
Below is a picture of a triangulated 4 bar setup. |
http://www.racetec.cc/shope |
Hey Billy,
What is your opinion about running a track locater as a lateral locating device on a street car? Andy |
Here we go again !!!!
Thank you Mr.Billy...
I am building a 31 model A coupe. I bought my rear pro street 4 link from Chris Alston,s Chassisworks. They told me it was perfectly fine to run a track locater on my car on the street. I also called TCI and asked them and they said yes ,they run them on the street all the time. I am not a professional chassis builder but they are and I respect their opinions.
Thanks for your reply Billy, but while the two styles of linkages perform the same function, they do it in different ways. It is my experience as a chassis builder that when a lateral locater was used in a street car that had cornering loads introduced, binding in the linkage would occur when body roll was present. I also noticed an improvement on rear axle tracking when going from a track locater to a Panhard bar (less "dartiness" or rear axle steering effect). I have found this to be true on more than one occasion. Not to mention the fact that spherical bearings typically used on these bars do not last very long in a dirty street car environment and even less time when water is introduced. In my opinion and others as noted in the links below, a Panhard bar is a far more effective lateral locater on a street driven car, and they are simple to build and install. As one caveat on a Panhard bar, it must be built as long as possible to fully realize the benefits, the kits that attach to the frame and to a bracket on the top of the third member are junk. Not only are they way to short, they also move the roll center of the rear axle way up.
http://www.swracecars.com/Files/pdf/CATpg36.pdf http://autoweldchassis.com/hardware.ivnu Andy |
Well you can keep useing your panhard bar,,, You seem to like to show me up,,I think we been down this road before... Maybe you are not setting up your track locater right.. It has been proved that it does work very well on the street.. And I'm sure Chris Alston, and TCI ..should both know what work's and what doesn't by now.. Man you just don't get it do you.... That's what is so great about hot rodding there is ''NO RULES'' You keep on doing what you want,, And I'll keep on doing what work's for me... Since you are so good at finding Info...Tell me why all the Dennis Taylor car are doing so good... I have a friend that drives his on the street and ''NEVER'' had any trouble like you say they do... I guess your answer will be,, He just lucky !!! YA RIGHT !!!!!
I agree that a properly built and installed panhard bar is stronger than a track locater,but most of us are not racing on a road course so a high quality track bar will work just fine.So just like the experts lets just agree to disagree.
| Unibody Rollbar Question | Thump_rrr | General Rodding Tech | 37 | 03-10-2009 10:55 AM |
| Rear crossmeber for coil over, weld in or bolt in? And.... Panhard or sway bar? | LiftFlat | Suspension - Brakes - Steering | 22 | 03-04-2008 05:49 PM |
| panhard bar watts linkage | lutze | Introduce Yourself | 2 | 12-27-2004 06:02 PM |
| Is a panhard bar appropriate for an elliptically suspended solid rear axel? | jpd37 | Transmission - Rearend | 12 | 12-17-2003 11:14 AM |
| Panhard bar revision | 5window | Suspension - Brakes - Steering | 2 | 11-06-2003 04:31 AM |
