Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4 bar suspension mock up
Old 06-25-2013, 08:03 AM
NEW INTERIORS NEW INTERIORS is offline
life is a temporary assignment
On your four bar set up the bars should be close to level with the ground... One bar won't be level and the other at a angle,, Your right about that,, It isn't a four link... When setting it up at ride height set them as close to level with the ground as you can.. Then set the cross bar where needed..
