Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4 bar suspension mock up
Old 06-25-2013, 10:23 AM
67-4-fun 67-4-fun is offline
Thanks for all the input. Right now the body is off the frame as I'm redoing the whole car. After doing more search I think most agree that the bars need to be more level. in order for me to level off the bars at ride height i want, going to have to raise the crossbrace to raise front bar location. i know what tire I want to run which is 30 inch . My plan is to slam the car down and tuck the tires slightly under wheel wells. I believe that would be about 3 or 4 inch drop from a factory setup. I know pretty much know where centerline of axle housing needs to be in relation to frame and body to get the look I want and have room for suspension movement and tire expansion. So I will do some more modification. I didn't want to back half the car as I think the 67-68 look better with mini tubs. Mine is tubed 2.5 inches.
