Is This A 4 Bolt Block? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2003, 05:44 PM
Bolt pattern looks like this looking under the motor and up at the crank.
b]Please Visit My Site[/b]
<a href="
target="_blank">http://www.geocities.com/montecarloss_01/Monte.html</a>
Old 06-16-2003, 05:53 PM
Dans83Olds's Avatar
Sucking Gas & Haulin' *****
if your block is a 4-bolt, u will have four bolts in each main cap. Two on each side of it. Hince 4 bolt main block. according to your diagram u should have a 4-bolt main block.
Old 06-16-2003, 06:05 PM
ya but it has just 2 bolts on both ends thats why I was asking, but ya it has 3 sets of 2 bolts on each side in the middle.
any other suggestions...by the way its a 1990 350 if that matters
ALSO NEED DIFFERENT SITE TO COMPARE CASTING #'S OTHER THAN MORTEC.
<a href="
Old 06-16-2003, 06:36 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
4 bolt chevy's only have two bolts on the front and back cap.
Chris
Old 06-16-2003, 06:38 PM
yes that is a 4 bolt configuration
Old 06-16-2003, 06:48 PM
Thanks alot guys. now..."ALSO NEED DIFFERENT SITE TO COMPARE CASTING #'S OTHER THAN MORTEC."
Anyone know of any good sites...THANKS A BUNCH
<a href="
Old 06-16-2003, 09:31 PM
banned
Have a look in our wonderful Knowledge Base
Old 06-16-2003, 10:08 PM
Ok listen I have a problem, now the first problem is that there appears to be no casting number on a block that I have (Anyone know were to look for newer blocks, its a 1990, its out and I looked everywhere but cannot find one). This motor is outta a 1990 G30 1 ton van...I checked the motor and its a 4 bolt. Now when I checked the head number on the driver side clyinder head it said 14102191 which is a head from a 1986-88 350 1.94 1.5001 - EFI, swirl port but thats the problem...its a 1990, is the site wrong? because this engine hasnt been touched that I know of.
HELP!
<a href="
Old 06-16-2003, 10:32 PM
you read wrong on mortec it says
14102191...87-up...350
the block casting number should be on the rear drivers side of the block on a similar plane to the head surface if its a greasy engine use a wire brush and search for it.. also check on the front passengerside deck surface there is a stampped number. this can also identify the block and its sometimes more thorough than the casting number.
Old 06-17-2003, 08:12 AM
Ya but mortec didnt give me much info so I checked http://www.nastyz28.com/sbchevy/sbch.html and looked at the numbers and got 1986-88 14102191 350 1.94 1.5001 - EFI, swirl port Did the site just mess up the years?
As for the locations you gave me I checked them and found nothing.
<a href="
