4 bolt mustang gt rear end,two left ford Ranger axles work in it? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-15-2008, 11:11 PM
Riley
Last journal entry: 1927 international
I would like to keep the rear end. I want to use it under a Chevy 1933 1.5 ton truck project. Problem is the rear end is a 4 bolt. I want a 5 bolt so I can put 15 inch tires on it. Someone told me to pull out the axles and put in 2 Ford Ranger 5 bolt axles in there and it will work. Does anybody know if this is true?
Old 08-16-2008, 10:22 AM
if your running a flange bolt up drive shaft rear end , they probably will work , even out of a aerostar van .
but as cheap as they run for price , just swap the by it all rear end your pulling axles from .
have you already cut and welded the spring perches ?
Old 08-16-2008, 09:07 PM
Riley
4 bolt mustang gt rear end,two left ford Ranger axles work in it? Reply to Thread
naw. I haven't did anything to the rear end yet. All I have done so far is pulled it out from underneath the Mustang.
Ford Ranger V8 Conversion izzymiddleton Hotrodders' Lounge 13 11-14-2005 11:23 PM
Ford Ranger 8.8" Rear Disc Brakes nightrain_rod Transmission - Rearend 1 06-23-2003 05:48 PM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
66 Ford Mustang rear end gears 66StangBoy Transmission - Rearend 3 11-18-2002 06:22 PM
ford mustang rear end and ratio edmilam@webtv.net Hotrodders' Lounge 3 03-27-2002 02:58 PM
