Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - from 4 door sedan to 2 door coupe.. torch time..!!!
Old 03-21-2011, 05:07 PM
Augusto's Avatar
Augusto Augusto is offline
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
Originally Posted by artsvettes
I have never done a chop job but have done some extensive body work over the years. I would put down the torch idea. To much heat generated from that. A sawzall and angle grinder with cutting discs would be my tools of choice
well actually I said torch just because it sounds cool, I will use my plasma cutter and the tools you mention, the oxy torch is reserved only for 1/2 or thicker cuts. and btw the plasma cutter head is also called torch.
what do you think of the idea?
