Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - from 4 door sedan to 2 door coupe.. torch time..!!!
Old 03-22-2011, 06:05 AM
redsdad redsdad is offline
Will I ever get it done?
Last journal entry: Driver's Door
If you are talking 2 door sedan, then yes. Lengthen the doors. buy EMS quarter repairs and move the B-pillar.
2 door coupe is a different animal. Trunk lid is different. Trunk hinges on the outside rather than inside. Slanted B-pillar. Different roof line.
My project journal has some good photos of what needs to be done to the floor and quarter area in front of the rear fender. If I were you, I would probably forgo roll up quarter glass. Glue the glass in. If I had it to do over again and knew how much time everything was going to take, I would have probably glued mine in and I had a set of window boxes to start with.
