4 inch hole grommet
Hi, I have two 4 inch holes I run my wires with plugends through the sheet metal. I am looking for a one piece grommet to keep the the wires from rubbing. Do any of you know where I can get a couple......? J-ree
You might want to get something like the rubber grommet that holds big truck taillights in that would work fine. JMO
Cole
Heres what i'm talking about, this it what my rig has in it and most any place that sell taillights for trailers and trucks will have them.
Cole
Grommets....
OR take a piece of vacum hose (or rubber gas hose,split in down one side.make your own grommets...
Re: 4 inch hole grommet
Hello..
If you are looking forward to the place where grommets can be easily available then I know one place. I hope the link help you in finding the best. Have a look at wire grommets | cable grommets . |
You did realize the OP is talking about 4 inch holes didn't you ? I wish he would post back and show us what he used .
Cole
what i showed the OP was not going to fill the hole just protect the wires as he stated. and besides that a split vaccum hose will not fit any size hole i would have to see that to believe it , all a split hose will do is if you wrap the wires in it then it will protect from rubbing the wires.![]() Cole
I've used split hose MANY times with great success on holes from 1/2" up to 6" (6" is the biggest I've ever used as a gromet).
As you have never seen it before, you simply split a length of hose the approx dia of the hole..... pick a point and press the split hose over thr edge of the metal and work your away around the hole till you reach the other end and cut to fit. Sometimes if it won't stay on a dab of RTV sealant will keep it attached. It also works very well protecting sharp edges on cut off oil drums. 3/4 " heater hose works very well to keep trash bags attached to the top of 35 gal barrels, bag inside folded over the top and use the split hose to clamp it to the top. |
| The Following User Says Thank You to EOD Guy For This Useful Post: | ||
eloc431962 (07-20-2012) | ||
Cole
| TH350 dipstick grommet | Oldguy48 | Transmission - Rearend | 1 | 08-16-2010 05:43 PM |
| carpet grommet | fiddyfofoad | Interior | 2 | 07-12-2010 07:59 AM |
| Speedo Cable Grommet? | Riverman | Body - Exterior | 2 | 09-18-2005 10:22 PM |
| Dimmer switch grommet | 5window | Interior | 6 | 05-27-2004 07:46 AM |
| wiring grommet | 38ChevyCoupe | Electrical | 7 | 01-14-2003 10:44 PM |
