4 inch lift - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2007, 07:47 PM
4 inch lift
should i put a new 4 ich lift blocks and new stock springs on my 1979 Chevy k10 or go with 4 inch lift springs all around. it already has a 4 inch lift springs in front and blocks in the rear what would ride better. another question just rembered what would cause it to lean on the drivers side would it be the blocks
Old 01-23-2007, 08:53 PM
topdogger's Avatar
Newskool
Last journal entry: New, Used grill arrived!
The leaning could be caused by shot leaf springs or in a worse case scenario twisted frame.
I would think that lifted leaf springs all around would give a better ride then blocks in the rear. I'm not to familiar with experimenting with 4x4's though.
Old 01-23-2007, 09:15 PM
right now i have blocks and it rides bad. i know i need new leaf springs all the way around the back are coming a part. and my shocks i can almost pull them off the bolts at the top. i can get the leaf spring kits for 489.99 bran new
Kwik Lift? bigbird Garage - Tools 26 07-27-2008 08:52 PM
low profile tires for 15 inch Halibrand reps peranaman Suspension - Brakes - Steering 3 06-28-2005 04:36 AM
1.7 to 1.8 ratio BBC rockers much diff...? Bumpstick Engine 6 04-28-2005 11:41 PM
Engine Lift Plates fredsbackyard Engine 12 10-18-2004 02:32 PM
cam base circle vs. lobe lift question S10xGN Engine 4 09-19-2004 10:31 AM
