you said that gapless rings are detonation prone, why is that? Also did you mean that the top rings that come in gapless ring sets are pre-gapped. I have a 406sbc that is my daily driver but probably shouldn't be, it has a full spool 4.56 gears and a 3800stall. It goes 11's in street trim. Recently I ran into some fuel problems which made the car crap out at 6000rpm in third gear, about a month of this problem finally hammered my main bearings, so I'm rebuilding the motor. What rings do you think i should put in it , it has been run for about a year. It is 30 over, the bores were exact for each piston, they're SRP, and it was torque plate honed. It had Speed-Pro moly rings. Upon tearing it apart i noticed a good amount of oily crud on the pistons was this blowby? The guy at total seal told me to have it honed with a 280 grit stone to knock the glaze off and to put a TS1 race set of rings installed dry, preferrably with the quickseat powder? Do you have any input.
Quick Seat Powder is made by Total Seal you rub it on the bores dry it supposed to instantly seal the rings. A populular engine builder in my area swears by it and so do other builders I've talked to. And I wasn't fibbing about my car it is the only vehicle I own, I'm 19 work at an auto parts store and am paying for Junior College by myself. Although friday nights in my car are great the weekday is a pain. although my car has a full interior and looks stock save for 31/2's in front and 2756015's out back it is a hassle because of no AC or heat and half the time my electric windows don't work, the power seat works all the time though. You would never guess my car has run as quick as 11.82 by the way it looks or sounds. Despite the fun, I need a beater truck. Thanks for the insight 4-Jaw
Yes i fixed the fuel problem it seems as though my 130 qph 14psi mechanical pump was to much for my stock fuel lines. Also the way it was plumbed was very questionable. Yes the cops no me due to my fair shair of street racing, I was never caught, I'd say I've raced at least 50 times on the street. After that stupid fast and the furious movie all the imports and turd monsters in my town started racing, there is so much police presence at the cruise nites that I'll never race on the street again, also at the speeds i'm going now it would be retarded to race on the street.
Very Wise. You only have to get the wits scared out of you once.
You might find it hard to find an engine builder who has 400 grit hones, most builders prefer a rougher bore because it covers mistakes and is foolproof. As long as you have nice round bores do it. You can do the same thing by using 400 grit sandpaper over the honing stones and deglaze that way, change paper often until the glaze is gone. Use aluminum oxide abrasive paper not emery cloth-emery cloths bond dissolves in oil. BTW formula 1 cars have bores that look like mirrors, there is no break-in to speak of. The problem with rough finishes with moly rings is it removes all the moly and your left with plain chrome, kind of defeats the purpose if you ask me. You are using 1/2"lines? Right? That kind of fuel flow needs the extra capacity of 1/2". Don't forget the pickup in the tank either, most stock pickups are pitiful. A fuel cell would be a good addition if you don't already have one, solves a bunch of problems all at once...not to mention being a whole lot safer. Getting a sender in the tank can be a problem with fuel cells, I like a sight glass. Looks cool too. Good idea to get a beater, with the fuel mileage your getting you could pay for two educations. I still can't believe I once drove a car everday that got 6 miles to the imperial gallon, lots of fun though.
Outlawed tunes from outlawed pipes |
