4 link anti squat - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2008, 04:21 AM
4 link anti squat
Hi all,
I am new on here but I have a question relating to anti squat on a 4 link live axle car. I understand the theory of having the arms converge etc to induce some anti squat and therefore improve traction under acceleration but I have a general question.
Is it better to have the convergence point close to the ground and further forward or higher and further back? I have done some calculations for my car and the figures turn out higher are with the convergence point further forward and lower to the ground. However, my concerns relate to the fact that to achieve this, the lower arms need to point downwards to the chassis which in theory will induce squat. Is this correct or am I wrong?
Perhaps my calculation method is wrong but I used one that I found on here
%Anti Squat = 100 / (IC Height / IC length from rear axle centre line) / (Cof G height / overall wheel base length)
Is this correct?
Many thanks
John
Old 10-16-2008, 04:58 AM
4-link
In chassis engineering handbook, under 4 link without a pan hard bar, the top links are horizontal to the ground, with the bottom ones angled upward and pointing inward to a convergent at about the output area of the transmission. Both show the same length.
Old 10-16-2008, 07:51 PM
When you screw with stuff like that there are a bunch of extra things you need to think about.
Here is a little spreadsheet that I (with help from some others) put together to work out some of the numbers.
http://mysite.verizon.net/triaged/fi...rLinkV3.1d.zip
If the convergence point (aka IC or Instant Center) is too close to the rear wheels you can get brake hop problems. Milliken & Milliken say shorter than 60" is too short.
The more you angle the links up (lower on axle and higher on chassis) the more roll oversteer you get. Some roll understeer would be better.
Play with it, do some research, see where stuff fits, and build it
Old 10-17-2008, 02:48 AM
Thanks all. I will play with the figures
John
Old 10-17-2008, 07:11 PM
Member Billy Shope on this site is a chassis engineer and has a website dedicated to your question, and much more. Explained in simple language.
Check with billyshope on this site, and here is a link to his website.
http://home.earthlink.net/~whshope/
Old 10-18-2008, 08:00 AM
Thanks - I have been in touch with Billy who has proved invaluable as has his website utilities.
John
89 dodge dakota anti lock and brake light on notmrgoodwrench Suspension - Brakes - Steering 14 06-05-2006 09:41 PM
Project Journal link not showing up 78novaman Hotrodders Site Suggestions and Help 11 07-23-2005 10:06 AM
Jon-Smilies link 5.0Towncar Hotrodders Site Suggestions and Help 5 03-03-2003 11:33 PM
4 link vs. triangulated 4 link. rear suspension bentwings Suspension - Brakes - Steering 4 11-23-2002 01:44 PM
