Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4-link or caltracs for s-10
Old 05-23-2005, 10:41 AM
TerroRx7 TerroRx7 is offline
New Member
Originally Posted by astroracer
Give us some background...
What are you doing currently to help traction?
What tires are you running?
Motor/Trans?
Before you do anything to tear up the truck you really need to optimize your current set-up. I will tell you right now that if you go to a set of CalTracs or Slide-a-links and a good drag radial tire you will have enough traction without a major rebuild...
Mark
I havent started the swap yet
I bought a 91 s-10 shortbed with a blown 4 banger
the motor is a blowthrough turbocharged ( pt88 turbo ) 355 sbc and it should make +800 rwhp
I will use th400+transbrake and either a 9-inch or a dana 60 rear end
I don't know what tires I can use but I've read that I can mount 28x10.5x15 slicks on 8" rim without any modification
