4-link or caltracs for s-10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2005, 08:46 AM
New Member
hello
I want to tub my truck so I can mount bigger slicks >> traction
so what method do you think is easy and effictive ?
1- tub the frame and relocate the leafs + adjusable coilovers +caltrac style bars
see this
http://www.cardomain.com/memberpage/400366/5
2- use a drag racing 4-link kit
3- copy the 4-link from a production car (G-body or B-body)
I don't know anything about 4-link design and theory so, I think the easiest and cheapest way is #1
this is a drag race truck but I love to drive it in the street
it will have a +500 rwhp sbc
any input appreciated
Old 05-23-2005, 09:59 AM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
Originally Posted by TerroRx7
hello
Are you looking for the cheapest way, if so relocating the leaf springs IMO is the way to go. You can reuse a lot of the same parts. If you do use the 4-link set up this is great, but they are sometimes difficult to adjust properly. But with that said they are ADJUSTABLE so you can fine tune. You can buy complete weld in back half kits for these trucks from many vender's but they are $$$ , they are quick and easy to install. Good luck with the project and keep us posted.
Steve
Old 05-23-2005, 10:16 AM
astroracer's Avatar
Give us some background...
What are you doing currently to help traction?
What tires are you running?
Motor/Trans?
Before you do anything to tear up the truck you really need to optimize your current set-up. I will tell you right now that if you go to a set of CalTracs or Slide-a-links and a good drag radial tire you will have enough traction without a major rebuild...
Mark
Old 05-23-2005, 10:41 AM
New Member
Motor/Trans?
Mark
I havent started the swap yet
I bought a 91 s-10 shortbed with a blown 4 banger
the motor is a blowthrough turbocharged ( pt88 turbo ) 355 sbc and it should make +800 rwhp
I will use th400+transbrake and either a 9-inch or a dana 60 rear end
I don't know what tires I can use but I've read that I can mount 28x10.5x15 slicks on 8" rim without any modification
Old 05-23-2005, 11:05 AM
astroracer's Avatar
As far as suspension mods you are putting the cart before the horse bud. Get it up and running with the mods I suggested and go from there...
Old 05-23-2005, 06:27 PM
S10xGN's Avatar
Gotta love a turbo!
Here's my S truck with Hoosier 325-50 x 15's on 10" Welds and Cal-Trac bars. Although it's a '96, the fenderwells are pretty much the same...
Russ
Project Journal link not showing up 78novaman Hotrodders Site Suggestions and Help 11 07-23-2005 09:06 AM
Jon-Smilies link 5.0Towncar Hotrodders Site Suggestions and Help 5 03-03-2003 10:33 PM
4 link vs. triangulated 4 link. rear suspension bentwings Suspension - Brakes - Steering 4 11-23-2002 12:44 PM
Parallel 4 link or Triangulated 4 link rear ? RonWood Suspension - Brakes - Steering 1 11-13-2002 07:25 AM
10 0/0 theory dinger Hotrodders' Lounge 3 09-12-2002 08:14 AM
