4 link HELP!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2008, 09:37 PM
ElguapoShoebox's Avatar
Nova Owner
4 link HELP!!!
Ok heres the story ... my 62 nova project i picked up is back half'd, fully tubbed with a 4 link and coilover setup already installed but i got the car minus the rearend ... so in my hunt i found a 9" out of a 66 bronco ... the next step is to get the 4 link brackets and install the rearend ... now is where i hit a snag ... i have little knowledge of 4 link setups or how to install them and i cant find a local shop that will even point me in the right direction. So im turning here in hope of finding the help i need to jump this hurdle ... thanks in advance for your help.
Old 03-04-2008, 11:30 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Take a look here, I've got a Chris Alston Eliminator II in my Nova, it's a task, but doable, I did it myself in my garage. If you have any questions you can't figure out from there, PM me. Look at my project journal for some real time pictures.
http://www.cachassisworks.com/cac_how_to.html
Semper Fi
Old 03-09-2008, 12:43 AM
techinspector1's Avatar
Wiki Edits: 326
Billy Shope explained it like this:
In the side view, visualize a horizontal line through the center of gravity (about the height of the camshaft) and a vertical line through the front tire patch. Then, a line...called the "no squat/no rise line"...passing through the intersection of these two lines and the rear tire patch.
Finally, visualize lines passing through the centerlines of your links. There will be an upper line (through the upper two links) and a lower line (through the lower two links). If you don't want the car to squat or rise, arrange the links so that the intersection of the upper line and the lower line falls on the no squat/no rise line. If you want it to rise, put the intersection above the line; squat, below the line.
Old 03-09-2008, 07:46 AM
My question is the Bronco rear end narrow enough ?? It is 58 inches wide, when measuring from wheel mounting flange to wheel mounting flange. Also, Bronco rears came with the 5 on 5.5 wheel pattern ( not the most popular pattern for a drag/street/strip car. Another thing to consider is the pinion offset is a good bit MORE on the Bronco than most other 9 inch Ford rears ( because it is offset for the 4 wheel drive ).
ALL early Broncos were equipped with 28 spline axles.
Most were the small axle bearing, most had 10 inch diameter brake drums ( Bronco ONLY ) making brake parts a little more difficult to find.
Old 03-09-2008, 09:25 PM
Nova Owner
The reason im using a Bronco 9 inch is because its only 3/4 of an inch off from a stock nova rearend, its got 4.10 gears and
i bought it for $100 .... I plan on replacing the brakes and im ordering a new set of moser axels with 5x4 3/4 bolt pattern
Old 03-09-2008, 09:38 PM
COOL ... most folks with a fully tubbed car that is back halved want a narrow rear end so they can run BIG, WIDE, TIRES ... with a narrow rear end.
5 link vette suspension fustkarr General Rodding Tech 11 11-29-2007 06:17 PM
Project Journal link not showing up 78novaman Hotrodders Site Suggestions and Help 11 07-23-2005 09:06 AM
4 link vs. triangulated 4 link. rear suspension bentwings Suspension - Brakes - Steering 4 11-23-2002 12:44 PM
Parallel 4 link or Triangulated 4 link rear ? RonWood Suspension - Brakes - Steering 1 11-13-2002 07:25 AM
