4-Link Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2005, 12:35 PM
rlackey's Avatar
Rich Lackey
Last journal entry: Rich Lackey is back on Hotrodders!
4-Link Question
I will be building up my '54 Chevy chassis with the original powerglide, enclosed driveline and rear axle, but I am considering replacing my worn leaf springs with a four link and air bags.
Is it possible to set up a four link on a rear axle with an enclosed driveline? I assume it should be no different than with a open driveline.
I don't know if this makes sense, but what I am trying to build is a show quality, well styled and detailed chassis using the original frame, original rear axle and driveline, Mustang II setup at the front with air bags and dropped spindles, four link at the rear also with air bags, but maintain a overall aesthetic that will look right at home under a old school traditional custom... modern ride and performance with old school style.
Any ideas? Suggestions?
Rich
Old 04-10-2005, 04:03 PM
BillyShope's Avatar
Philippines Cowboy
Last journal entry: THE TRACTION DYNO
I suppose, if you like the looks of a 4link, you could fabricate telescoping links in all 4 locations. You certainly wouldn't want them functional. They simply are not compatible with the torque tube suspension. What you'd have would be equivalent to a non-functional hood scoop. And, I see nothing wrong with this. Again, if you like the looks, go for it!
Old 04-10-2005, 04:10 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
4 link
The purpose of a 4 link is to get traction and to tub. It is not generally used for stock rear housing. Its a lot of money to put out not to tub. When you tub you lose the back seats. There are less expensive ways to get traction if you are not going to tub. You may want to look into a 4 bar out of a g body.
Old 04-11-2005, 03:24 AM
rlackey's Avatar
Rich Lackey
Thanks for the input, well, this being the case I think I'll forget about the 4-link unless I decide to go the whole hog with a narrowed Ford 9", narrowed frame rails at the back, tubs and obviously lose the enclosed driveline, and probably the powerglide too, although I have been told that the powerglide will put up with some real abuse if it's rebuilt with racing in mind.
I have thought about this before, and just doing away with the back seat as you say may give me other advantages anyway as I will be building this car with a retractable hardtop, and if I lose the rear seat, it will give me more room for the mechanism and folded roof sections.
It's a fundamental question of purpose I think, to cruise, or to race, or to be an art piece, but I would like a combination of all three. I need to work on defining what this car is, and when I have a good grasp of its intended function, I think form must follow that.
For a cruiser, the original rear axle and torque tube setup is fine, but for anything more, it's not going to cut it I think. Also, for a race car, the idea of a retractable hardtop with all it's complications and added weight of the mechanism doesn't make a lot of sense, not to mention complicating installing any kind of a roll cage. I mean, apart from maybe some smaller roadsters, how many full size convertibles do you ever see racing?
I'm just glad that it's early days as far as building is concerned, so I still have some flexibility in the end design of the car.
Hmm... lots to think about, thanks!
Rich
Old 04-11-2005, 07:26 AM
BillyShope's Avatar
Philippines Cowboy
Well, for one, there was Tom Hoover's hemi-powered '57 Plymouth convertible that held the C/GA records.
Old 04-11-2005, 07:46 AM
rlackey's Avatar
Rich Lackey
Billyshope, Do you have any idea where I could find some more info on the '57 Plymouth. I'll also do some internet searches and see if I can come up with anything.
Thanks so much!
Rich
Old 04-11-2005, 07:58 AM
rlackey's Avatar
Rich Lackey
Hmm, I couldn't find anything specifically on that Plymouth so far, but I did find that it seems roll bars are only required on convertibles that run 12.99 or quicker.
Old 04-11-2005, 08:18 PM
Lou's Avatar
Lou Lou is offline
Last journal entry: some more body shots
4-link Vs 4-bar
If youy want to put bars on that 54 you don't want a 4-link you want a 4-bar. If you use a 4-bar you won't have to get rid of the back seat. if you run a triangulated 4-bar you don't need a track bar or any other locator. If I can figure out how to post pictures i'll post some. Of a 63 Nova wagon with bags.
Old 04-11-2005, 09:00 PM
53LEDSLED's Avatar
here to learn
Last journal entry: finishing up the skirts
hey, i put a four link and air bags on my 53, i think they are the same as your car. check out my project journal and if you have any questions....well you know what to do.
Drag Link Question (Center Tie Rod) Houman SS '70 Suspension - Brakes - Steering 2 03-26-2005 09:56 PM
4 link question Kurt Suspension - Brakes - Steering 6 12-11-2004 03:50 PM
3 link question Weimer Suspension - Brakes - Steering 14 03-16-2004 12:42 AM
Nother 4 lInk Coil Over question scott011422 Transmission - Rearend 1 07-18-2003 08:50 AM
Hotrodders Guidelines -- READ ME Jon Engine 0 06-14-2003 05:53 PM
