-   -   4 Link Question... (http://www.hotrodders.com/forum/4-link-question-65345.html)
S10xGN 07-06-2005 09:02 PM
4 Link Question...
How important is it to set negative pinion angle on a 4 link? I'm thinking that the reason for negative pinion angle (at least on street cars) was for the factory suspension to allow the pinion to rotate up to a more neutral angle on hard acceleration due to the sloppy rubber bushings. With quality parts in a 4 link, this negative angle doesn't seem as necessary...
Russ
bracketeer 07-06-2005 09:11 PM
pinion angle
The more Hp, the more upward rotation, the more neg pinion angle req'd. Stock is about 4 deg, hotrod 6 deg. If you feel you have less rotation due to neoprene bushings, you can stick with the 4 deg.
S10xGN 07-08-2005 08:09 PM
I guess my thinking is this: are you going to have the "rotation" with a properly designed 4 link? There is nothing that will give, at least not like the rubber bushed stock stuff.
