4-link/rear end question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2006, 09:37 AM
brian12c's Avatar
I need to find a rear end for my s/c dragster with 4-link brackets that are 16" center to center. The only one I have found so far is a Mark Williams 12 bolt, which makes sense because the blueprints for the dragster were Mark Williams. The 12 bolt seems extremely expensive. Would there be any interference problems with purchasing a 9" chassis engineering housing and welding on the 4-link brackets myself? Chassisworks only goes as narrow as 16 1/2" and Strange only 17". Do I have any other options? I'm sure the M/W housing is a professional modular housing but at $1,500 for a bare housing and $4,800 loaded it seems very expensive. Thanks, BF
Old 07-14-2006, 11:00 AM
Might try Moser Engineering, or Undercover Chassis! If I were changing I would go with a 9 IN Ford no matter what the cost.
front end question jbowman Suspension - Brakes - Steering 8 11-29-2007 08:48 AM
NASCAR style quick change rear end question Jeeper426 Transmission - Rearend 3 06-21-2006 04:24 PM
Rear end swap question pearldrumbum Transmission - Rearend 1 05-21-2006 12:16 AM
Stall Converter and Rear End Question 68 Impala Man Transmission - Rearend 2 09-28-2003 09:49 AM
Mustang II front end Question horvath Suspension - Brakes - Steering 35 03-02-2003 04:08 PM
