I will move this to the suspension section for the guys there to offer some advice.
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Here's a short piece I wrote that may help. Your MIG should work just fine. I use a 200 amp Lincoln, but never have it cranked up for welding such as this.
http://streetmachinesoftablerock.com...opic.php?t=425 |
hey there tech, youre all over the place arent you? (different forums i mean). so its absolutely imperative to have a level floor?? ok, i like the idea of using the plywood, it may take a little time to build but what the hey....... thanks for your input. |
Might be helpful...
Another thing to consider is some adjustable jack stands... I use them for all my suspension work... I got mine from Camping World but you can probably get them anywhere...
The problem with "regular" jackstands it always seems to me I need that "in between" spot they don't have.... http://www.campingworld.com/browse/p...33&prodID=1714 These allow you to adjust in small amounts... Good Luck! Aaron |
| How to install a chimney for a wood heater | rusttorod | Garage - Tools | 31 | 11-06-2006 08:56 PM |
| Project Journal link not showing up | 78novaman | Hotrodders Site Suggestions and Help | 11 | 07-23-2005 09:06 AM |
| 34 pontiac 81 camaro subframe install ? | mobythevan | Suspension - Brakes - Steering | 7 | 05-19-2005 12:17 PM |
| coil spring install on camaro subframe | kid | Suspension - Brakes - Steering | 3 | 08-25-2003 06:26 PM |
