4 plug connector off the distributor - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2010, 04:36 PM
spinn's Avatar
My quick search on 4 pin HEI connector, lead me to the 4 pin dwell modules. My distributor has a cable that splits at a soleniod on the firewall, and then transmisson. What is the 4 plug connector for ? Will Everything operate fine without it ? using a new ebay $40 HEI ?
Old 10-18-2010, 05:38 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
The 4 pin connector indicates that this is an electronic spark timing distributor.
It is controlled by a computer. In 1980 GM started a transition from centrifugal timing control to electronic and there are several iterations of this.
So if your car has all original factory computer controls you can get it to work but the distributor won't work alone.
vicrod
Old 10-18-2010, 05:58 PM
spinn's Avatar
Thanks
To clarify. Running a NEW normal GM HEI w/ a vacuum advance, Just working off the battery+ , throttle, and TV line it will not work.
Old 10-18-2010, 08:02 PM
spinn's Avatar
How can it be converted to a normal 4 pin Hei and keep the driveability fully functional? The lockup TH350C converter and 10 degrees of retard are cointrolled here possibly.
Ignition system info................ poncho62 Electrical 18 10-11-2008 10:10 PM
Spark Plug brands question Francis Engine 65 07-15-2008 12:01 AM
distributor or alt plug wayneair Electrical 1 11-04-2005 04:28 PM
bent push rods teds 46 Engine 2 09-06-2004 12:12 PM
Distributor or Plug problem? 54 Chevy Engine 3 05-25-2002 06:35 PM
