4 speed AOD installed on a '75 Torino - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2006, 01:42 PM
Last journal entry: Nick's '75 Torino
What kind of problems am I looking at in the beginning? I 'got a 351 W and a C4 now. I would like to install a 4 speed AOD to match with my 351 W. If I go with a manual AOD and some type of floor shift (possible a Quicksilver or something similar; any suggestions?) Is this an easier install than the electronic AOD.
Any help and suggestions are welcome. I'm located in the Metro Detroit area.
Milford Nick
mkamich@comcast.net
Old 03-19-2006, 05:57 PM
Cobra Pilot
I recently installed a Ford AOD transmission behind my 351C. It originally had a C6, but with a 3.73 rear I definitely needed a overdrive. I did alot of research and found I had to replace my flexplate. I understand with the 351W it is a simple bolt up operation. I had a local shop rebuild a AOD from a pickup, because it has more internal clutches. I also allowed them to install it, so I would have a warranty. With the AOD, a TV cable is required and runs from the tranny to the carb. It is critical that this be adjusted properly or transmission failure will result. (Another reason why I had the shop install it). Also make sure you at least get the transmission yoke so you can adapt it to your driveshaft. I have over a 1000 miles on my transmission and I love it. At approx 1800 - 2000 I'm running about 60 mph. I'll see if I can locate more info and pass it on to you. Good luck, Everett.
Old 03-19-2006, 06:29 PM
Cobra Pilot
Hey Nick, alittle more info for you. I used a Lokar shifter, TV cable and dip-stick. They have a web site, just type in Lokar. I also got alot of info from www.transmissioncenter.net/aod.htm. Very helpful. They make a conversion kit to switch a AOD transmission to any 289/302/351W. I used the AOD because it doesn't require any electrical hook-up. I like it simple. My 351C is running approx 400 hp, and I'm using a 2800-3000 stall converter and an auxiliary cooler, seems to be a great set-up. I'm running it in a EM-Cobra which weights just under 2000lbs. Hope this helps, Everett.
Old 03-19-2006, 06:46 PM
BarryK's Avatar
I installed an AOD on the 57 Tbird 312 and the trans was purchased from the previous posting "The transmission center" good people to deal with and the trans has been great.
I keep the same floor shifter so purchased the Locar AOD kit and TV cable.
Very easy to install and than had a transmission place adjust to pressure.
It was a very simple job!!
Since then I have gotten a pedal and cable assembly off of a 90 T-Bird and adapted to my system so I could eliminate the original bell crank.
(my showing days are done)
All said and done its the best money I could have spent, gas mileage doubled (just short) and it will now keep up with a new Mustang till about 70 or so.
Its a totally different car but if I did it again I would have installed a computer AOD.
Old 03-20-2006, 11:17 PM
4 speed aod replaced on a 75 torino
Everett,
Can you tell me about the flexplate change you had to make. I just did some research on installing a later {94} AODE behind a 70 351c and I thought the flexplates were the same. I took the original 94 flexplate to an auto parts store and compared it with a flexplate for a 351c c6 combo and they were identical. I am getting ready to do the swap and now I am concerned I may need a different flexplate. Thanx, Bob myers, SD.
Old 03-22-2006, 09:20 AM
Cobra Pilot
Hi Bob, Before I did my C6 to AOD swap I checked with the transmission center.net and they had plenty of info. They told me that the stock 351C flex-plate would not work due to its thickness. This would cause early front pump failure. They even have a single sentence stating this on there site. Check them out. I continued to check other sites and found Windsor-Fox.com. They had a flexplate that would work with my swap to an AOD. I purchased the Windsor-Fox flexplate, block plate and bolts for the install. Check there site, especially the Frequently asked question column. Good information there. After I received the parts, I checked them to my original and found, like you that the dimensions were the same, even the blockplate was the same thickness. The only difference was mine had a lightweight flexplate and the Windsor-Fox flexpate was a standard. Both were the 28.2 oz. I used the new parts, but guess I really didn't have to. Take a look at the sites and see what you think. Good luck with your install, Everett.
New BG Speed Demon installed – Disappointed Horse_pucky Engine 55 10-09-2005 12:42 AM
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 03:36 PM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 12:48 PM
75 c4 or 83 aod? ping001 Transmission - Rearend 1 02-12-2003 11:34 AM
My AOD, the full story mustang66maniac Transmission - Rearend 26 01-30-2003 04:38 AM
