4 speed, borg warner - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-20-2005, 02:31 PM
my friend bought a 81 camero with a 4 speed trans. he was told it's a muncie , but turns out it's a borg warner. i know t4/t5's are top loading, n' this one isn't. does that mean it's a t-10? p.s. the nova runs great! turns out it was an intake leak on cyl. #'s 6 n' 8. no more popping!!
Old 11-20-2005, 08:21 PM
poncho62's Avatar
Wiki Edits: 5
T-10s look very much like Muncies........the reverse lever is in the tailshaft, as is a Muncie. If the reverse lever is in the side case, it's a Saginaw trans.
If you want to check out the numbers, look HERE
Old 11-22-2005, 08:46 AM
Last journal entry: PICTURE TEST
trans
If it's cast iron then is a saginaw trans.
If it's aluminum then it's either a muncie or T-10. The fastest way to tell is count the side cover bolts.
7 bolts = Muncie
9 bolts = T-10
Plus all T-10 made after 73 or so have borg warner cast right on the side....
Keith
5 speed borg warner trans specs martion Transmission - Rearend 3 11-23-2005 04:11 PM
Borg Warner VS Richmond 5 speed Johnny 5 Transmission - Rearend 1 03-26-2005 08:35 PM
Borg warner 5 speed Scuzzy Transmission - Rearend 5 10-17-2003 01:01 AM
Replacing Borg Warner T10 with Richmond 6 speed beazil Transmission - Rearend 3 05-16-2003 08:59 AM
borg warner 4 speed 4doorjoe Transmission - Rearend 1 01-07-2003 07:25 PM
