4 speed convershion - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2003, 02:30 PM
4doorjoe's Avatar
Post 4 speed convershion
I am just about ready to replace my glide with 4 gear i have new pedel cluster for clutch does any body know if i have to change the whole cluster or will the clutch pedel shaft just slide into existing brake pedal from automatic set up this is on a67 biscayne thank you <img src="confused.gif" border="0">
Joe sammut
Old 02-09-2003, 03:18 PM
Thumbs up
Well if it was me I'd replace the whole assembly due the width of the brake pedal on automatics, the wider pedal could get in the way and lock up the brakes instead of disengaging the clutch. I hope this helps.
Old 02-09-2003, 03:31 PM
ssaza's Avatar
Post
need to replace both pedals,as the automatic brake pedal is larger that the brake/clutch pedal.the pedals have a pin with a metal clip,pull the clip out and then the pin,replace with both the clutch and brake pedal,easy change.
Old 02-09-2003, 03:39 PM
4doorjoe's Avatar
Post
Thanks guys so i understand what you mean about the pedals so the actual cluster stays on just pull pinann replace both pedals am i reading you wright or does the whole bracket have to come out thanks
Joe sammut
