Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4 speed manual
Thread: 4 speed manual
Old 07-21-2003, 01:20 PM
11echo's Avatar
11echo 11echo is offline
Old Guys Rule!...EVERYTHING!
The 235 is the same as a 194 & 250 ...in line 6's. AND the same trans pattern as the small block. But there is a difference between the 3 spd's and the 4 spd's bell housings. The bolt pattern is the same but the pilot (ring around the input shaft is different - (not the pilot bearing)). I have a 85 4 spd. Saganaw behind my 235 now, bolt up item. Hope this helps! ...Mark
