Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4 speed manual
Thread: 4 speed manual
Old 07-22-2003, 03:11 AM
jimfulco jimfulco is offline
A 235 is a totally different engine from the 194, 230, 250, 292 series. It has a different bellhousing flange bolt pattern. You may be able to use a later 4-speed trans with your present bellhousing, but I'm not sure. I read somewhere that the front trans bearing retainer changed diameter somewhere around 1967 or so, but again, I'm not sure of this.
