-   -   4 speed manual (http://www.hotrodders.com/forum/4-speed-manual-19506.html)
APACHEMAN 07-14-2003 09:12 AM
4 speed manual
Is there a four speed manual out there that will bolt to a pre 63 235?
jimfulco 07-19-2003 01:02 PM
What's in it now?
APACHEMAN 07-21-2003 07:22 AM
A three speed.
gt2betubbed 07-21-2003 09:20 AM
Never seen a 235, but isn't there a bellhousing? I would think it mattered more on that than the motor.
11echo 07-21-2003 12:20 PM
The 235 is the same as a 194 & 250 ...in line 6's. AND the same trans pattern as the small block. But there is a difference between the 3 spd's and the 4 spd's bell housings. The bolt pattern is the same but the pilot (ring around the input shaft is different - (not the pilot bearing)). I have a 85 4 spd. Saganaw behind my 235 now, bolt up item. Hope this helps! ...Mark
jimfulco 07-22-2003 03:11 AM
A 235 is a totally different engine from the 194, 230, 250, 292 series. It has a different bellhousing flange bolt pattern. You may be able to use a later 4-speed trans with your present bellhousing, but I'm not sure. I read somewhere that the front trans bearing retainer changed diameter somewhere around 1967 or so, but again, I'm not sure of this.
