The 235 is the same as a 194 & 250 ...in line 6's. AND the same trans pattern as the small block. But there is a difference between the 3 spd's and the 4 spd's bell housings. The bolt pattern is the same but the pilot (ring around the input shaft is different - (not the pilot bearing)). I have a 85 4 spd. Saganaw behind my 235 now, bolt up item. Hope this helps! ...Mark
A 235 is a totally different engine from the 194, 230, 250, 292 series. It has a different bellhousing flange bolt pattern. You may be able to use a later 4-speed trans with your present bellhousing, but I'm not sure. I read somewhere that the front trans bearing retainer changed diameter somewhere around 1967 or so, but again, I'm not sure of this.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
